The number of links in Selected state has fallen below the minimum required for the LAG to remain up.
Check to make sure links are active via show port sharing command. Verify that all links are properly configured with LACP and communicating correctly using show lacp commands.
Warning
The number of links in Selected state for LAG %port% with %totalMembers% member ports has fallen below the minimum %threshold% links in Selected state required for the LAG to remain up.
| Name | Type |
| port | String |
| threshold | uInt8 |
| totalMembers | uInt8 |
